1991 Chevy Cavalier fuel pump
120,000 MILES • 4 CYL • FWD • AUTOMATIC
LOUIE G.
Fuel pump was replaced by thiis mechanic and when I tried to started it wouldn't. I could hear the pump working. He removed the line that goes to the carburator and no gas was coming out what could it be? Is their a hose inside the tank that connects to the fuel pump or is all pressure that builds up inside the tank?
Apr 18, 2010 at 11:37 AM
BMRFIXIT
  • 19,053 POSTS
If you hear the pump coming on and no fuel pressure check fuel filter and yes the pump connect to the sender by a hose and secured by a clamps
Remove the pump and check
Apr 18, 2010 at 1:52 PM
