1991 Chevy Cavalier Driving then RPM drop with no throttle
93,000 MILES • 6 CYL • FWD • AUTOMATIC
DWNINIT2001
I will be driving along and try to speed up. Seems fine til 3000 RPM then lose power. RPM gauge drops til it hits idle at about 1000 RPM then sometimes regains or stalls all together. Now having trouble even getting it restarted.
Oct 11, 2010 at 12:45 PM
HMAC300
  • 48,601 POSTS
you'll need to check your fuel pressure as it may be low causing this. it would be a good time to change the fuel filter as well.... if not you'll need your ignitions system checked out.....
Oct 12, 2010 at 1:06 PM
