1991 Chevy Cavalier
103,980 MILES • 4 CYL • FWD • MANUAL
MPEARSON20
Car will only run for about 5 minutes and then it sputters and dies. Any ideas why this is happening?
Jun 24, 2010 at 8:39 AM
  • 75,988 POSTS
Next time it dies out don't wait do below immediately to determine if its a fuel or spark related issue
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 24, 2010 at 10:14 PM
