1991 Chevy Cavalier
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
LOUIE G.
Does this car takes an RFI screw, if it does where does it go. Fuel pump was replaced by this no pride in his work mechanic and relay checked. I do not hear the pump workiing. what could it be? Please help. THANK YOU, Louie
Apr 26, 2010 at 9:53 AM
RHALL77
  • 3,361 POSTS
what do you mean by a RFI screw? For your fuel pump, check your fuses and see if any are blown. If they are ok, you may have to drop the tank down alittle and see if your getting power to the connector. Another quick thinik you can to is use a rubber mallet and hit the bottom of the gas tank and see if the fuel pump will turn on. Let me know what you find out and Ill see if i can further assist you.
Apr 27, 2010 at 6:23 AM
LOUIE G.
Thank you for steering me in the right direction. I am replying to your answer, I checked the fuses which looked OK, but I couldn"t tell with the 10 amp fuse, so I compared it to a new one and bingo, the fuse was blown. I replaced it and started the car and it ran great. THANK YOU VERY MUCH SIR.
Apr 27, 2010 at 9:51 AM
