1991 Cavalier serpentine belt replacement
MGREENLEAVES
Hi; I have a problem trying to get a belt replaced on my '91 Cavalier, 2.2L with no A/C; there is no visible belt diagram as it was painted over. I have just replaced the alternator and I think I have the belt going on correctly, but I can't get it completely into place because I can't find any type of tensioner. After reading a couple of articles, I am led to believe that this vehicle has an idler wheel...if this is the case, can I just release tension on this idler wheel in order to slip the belt into place? I would appreciate any help I can get with this problem. Thanks; mgreenleaves
Feb 20, 2007 at 9:27 AM
CHEVY22
  • 1,375 POSTS
hey
the 91 2.2 does have a tensioner , it is located below and between the alt and p/s pump its either a 13 , 14 or 15mm put a socket on it and push towards the front of the car easy and slip the belt on
Feb 20, 2007 at 10:09 AM
