1990 Chevy Cavalier speedometer
BBY7522
Transmission problem
1990 Chevy Cavalier 4 cyl Front Wheel Drive Manual
i need to know how to take the cable out and get the speedometer to work without the cable...the trans is out of a 92
Apr 14, 2008 at 8:56 AM
BLACKOP555
  • 10,386 POSTS
your taking a speedometer that runs off of a speedometer cable and you want to put in an electronic one?
if thats the case you will have to buy a new cluster that will run off of the VSS.
Apr 14, 2008 at 12:08 PM
BBY7522
yes my car is a and the trans is a 92 but yes something to get it to work ....so would i need to get the computer or how would i do that ?
Apr 14, 2008 at 1:32 PM
BLACKOP555
  • 10,386 POSTS
if your transmission your putting on has a VSS you can probably talk to a autopart store and see if they can get you a aftermarket one that can be hooked up to the VSS. VSS = vehicle speed sensor.
Apr 14, 2008 at 2:23 PM
