Based on the info you have provided I would check the ignition module. I am not sure what you mean by "Checked and bypassed the crank position switch"
The crank shaft position sensor should not be jumped out. If that is what you mean that should be your first step to hook everything back up and start fresh. The fact that it was running a little about 5 min. and now you have a no start condition. Sounds
to me like you replaced a bad part with a bad part. If possible you should always replace an electronic device with a new one.
I understand that is not always an option. Please make sure your CSPS is hooked up and replace the ignition module. If you are doing the work yourself and labor cost is not an issue you could put the old one back on just to verify my suspicion that the used one is bad. If it starts and runs for about 5 min. you will know. Good luck.
Jan 10, 2019 at 10:49 AM
(Merged)
