1990 Chevy Cavalier Hard to shift the trans into 2,4,or Rev
30,000 MILES • 4 CYL • FWD • MANUAL
ERIRISH
  • 5 POSTS
I have a 1990 Chevy Cavalier with over 300,000 on it. Has been a great car, but now the it has gotten very hard to shift it in to 2, 4, or Rev. I'm a pretty strong guy and can muscel it into grear, but it's not easy at all. 1, 3, and 5th all seem fine. I don't think the clutch has ever been replaced on the car. So, that's kind where i'm leaning, but I would think it would start to slip or grab. There is none of that. Can you guys help me out.
Thanks
Eric
Feb 22, 2008 at 3:39 AM
2CARPRO JACK
  • 11,533 POSTS
Those are all back towards you on the shift pattern? Might be a shifter bushing problem if the others are ok
Feb 22, 2008 at 3:49 AM
ERIRISH
  • 5 POSTS
Yes all the shift pionts are back towards me. I was reading other sites and some say to replace the clutch. I figure that it needs to be done anyway, after 300,000 or so. So, I think that I going to replace the clutch. Where are the shifter bushings located, I imagine in the transmission, but are they easy to get to?
Feb 22, 2008 at 3:56 AM
2CARPRO JACK
  • 11,533 POSTS
On the shifter itself. Down at the pivot point or where the shift cable or rod attaches to the trans
Feb 22, 2008 at 4:13 AM
ERIRISH
  • 5 POSTS
Cool I'll defiantly look there first. That sounds easier then pulling the trans. Thanks
Feb 22, 2008 at 6:57 AM
2CARPRO JACK
  • 11,533 POSTS
Not sayin you didnt get your moneys worth with 300k on that clutch... never heard of that many miles on one before
Feb 22, 2008 at 7:51 AM
