1990 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 196K miles
I replaced water pump at 148K, it started leaking at 196K and when I removed it the impeller vanes were worn completely off! What could have caused this?? Also if this car gets 1 gal. low on coolant the engine sputters and dies at stops when it's cold, add coolant and it runs fine, is this a designed in safety feature and how on earth would it work? Curious, Thank you
Jan 29, 2008 at 10:09 AM
