1989 Chevy Cavalier Trouble code 24
AZTROPIC
Computer problem
1989 Chevy Cavalier 6 cyl Front Wheel Drive Automatic 190K miles
1989 Chev cavalier Z24 2.8 automatic always sets code 24(VSS) after it is warmed up,and within 3 to 5 seconds after coasting above 50 MPH (digital dash) Over the years,I have replaced every possible sensor including a different throttle body and computer with absolutely no change.Begining to suspect something mechanical like a broken or grounded wire or vacuum leak. Any ideas? Any list of conditions that need to be met before triggering code 24?
aztropic
Aug 29, 2010 at 5:55 AM
DOCFIXIT
  • 18,828 POSTS
With DVOM on AC scale mearure voltage across VSS sensor on transaxle. jack up in gear if voltage present then check at ECM
Aug 29, 2010 at 6:44 AM
AZTROPIC
Nope! definately not a computer problem.Tried a brand new one and a known good one from a friends car with the exact same results.
Would be interested in knowing the parameters that cause a code 24 to be set.(vehicle speed,voltage at throttle position sensor etc.)
Aug 29, 2010 at 4:04 PM
AZTROPIC
Will check for AC voltage at ECM. (Digital dash speedometer works fine) Thought speedometer # MPH was created by the ECM from VSS voltage signal?
Aug 29, 2010 at 4:22 PM
DOCFIXIT
  • 18,828 POSTS
Only two things set code 24 faulty VSS or PROM
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_589.jpg
Aug 30, 2010 at 6:58 AM
