HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Cavalier
Engine
Cylinder Head
Rocker Arm
SPONSORED LINKS
1989 Chevy Cavalier Torque Specs
SIR WADE
MEMBER
1989 CHEVROLET CAVALIER
Engine Mechanical problem
1989 Chevy Cavalier 6 cyl Front Wheel Drive Automatic
What is the torque specs for rocker arm stud on 1989 Chevrolet Cavalier Z24 2.8 engine?
Sunday, January 10th, 2010 AT 7:08 PM
BLUELIGHTNIN6
MECHANIC
If your vehicle has the 2.8L engine and the 8th digit of your VIN is "S" then it has adjustable valves and should be 1.5 turns down from zero lash.
If its any other application then rocker arm nut will be tightened to 18 Ft. Lbs. (24 Nm)
SPONSORED LINKS
Sunday, January 10th, 2010 AT 9:46 PM
Please
login
or
register
to post a reply.
Related Cylinder Head Rocker Arm Content
1991 Chevy Cavalier Rocker Arm Torque
I Would Appreciate Help With Adjusting The Rocker Arms On My 1991 Chevy Cavalier 2.2 Motor. Have Found Several Specs But None Are Constant...
Asked by
dragonstorm
1 ANSWER
1991
CHEVROLET CAVALIER
VIDEO
Rocker Arm Replacement
Instructional repair video
1996 Chevy Cavalier Nurse In Trouble!!!! ... Damaged...
Engine Mechanical Problem 1996 Chevy Cavalier 4 Cyl Manual 210000 Miles My 96 Cavalier Was Running Beautifully, And Then Starting It...
Asked by
JL007
1 ANSWER
1996
CHEVROLET CAVALIER
1989 Cavalier
I Have A 1989 Cavalier, 2 L, Auto, 175000 Km. Recently Did The Head Gasket And It Runs Well Now. Had To Disconnect Throtle Valve Cable...
Asked by
toronado_85
1989
CHEVROLET CAVALIER
Head Bolt Torque
Im Replacing My Head Gasket I Am Needing To Know The Tork On The Head Bolts
Asked by
dragonmist1034
2 IMAGES
2002
CHEVROLET CAVALIER
Cam Index After Head Gasket
2.2ecotec Swapped Head Gasket On Daughters Car Because Of A Broken Timing Guide (heads Fine Did Not Bend Any Valves) Had Her Boyfriend "...
Asked by
yetiford1
3 IMAGES
2004
CHEVROLET CAVALIER
VIEW MORE
SPONSORED LINKS
Oil Change Filter Replacement Subaru
Engine Oil Change and Filter
Online car repair manuals
