1989 Chevy Cavalier i need help
249,000 MILES • 6 CYL • 2WD • AUTOMATIC
THADW
i have black smoke coming out of my air filter and i,m bringing up a trouble code 35 do you have any idea what it could be?
Nov 11, 2008 at 5:20 AM
  • 110,248 POSTS
Hi:
A code 35 is for the Idle air Control Valve (IAC). It's only purpose it to keep the engine idle steady. I don't know if that is your problem. The black smoke coming through the air filter makes me believe that you may have a problem with one or more intake valves. You will need to check the engine's compression to determine if the valves are bad.
Let me know what you find.
Nov 13, 2008 at 8:23 AM
