1989 Chevy Cavalier cavailer z24
450,000 MILES • 6 CYL • FWD • AUTOMATIC
89CHEVY
HI I have a 1989 chevy cavalier z24 with a 2.8
the car has a lot of miles on it 450000 thousand
the problem is I replaced the crank sensor a year a go and the Engine Module. and it ran fine but now it will start and run but it will start to miss and then die and you will not start again until it is cold again then it will start and the do the same thing over I check the fuel presser its fine I think its the module but not sure could you help with this. also when it is running when you Rev the motor it will try to die but if you let off the gas it will stay running
Jan 20, 2009 at 9:10 AM
MMPRINCE4000
  • 8,548 POSTS
Remove ignition module and have it tested at any autoparts store for free.
Classic symptoms of ign. module failure are runs OK cold but dies hot and will restart when cold again.
Jan 21, 2009 at 1:22 AM
