1989 Chevy Cavalier 1989 Chevy Cavilar idle increases
177,000 MILES • 4 CYL • FWD • MANUAL
W1PLW
I have a 89 Chevy Cavilar. my problem is sometimes it increases engine rpm all by it's self.
It seems like something is sticking. sometimes it increase slightly then returns to normal. other times it revs right up and stays there and I have to shut it off and restart it and it seems fine.
Jun 15, 2008 at 5:51 AM
  • 75,988 POSTS
Too fast an idle speed. If an engine without computerized idle speed control is idling too fast and refuses to come down to a normal idle speed despite your best efforts to back off the carburetor idle speed screw or air bypass adjustment screw (fuel injection), air is getting past the throttle somewhere. Common leak paths include the carburetor and throttle body gaskets, carburetor insulator spacers, intake manifold gaskets, and of course, any of the engine's vacuum fittings, hoses and accessories. It is even possible that leaky O-rings around the fuel injectors are allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft and a defective idle speed speed control motor/valve stuck in the extended (high idle speed) position/throttle position sensor. Also the throttle plate could be binding in its bore and kinked accelerator cable, coolant temperature sensor might not be operating properly misleading the computer that the engine is still cold and computer throwing fuel at it raising the idle speed.
Jun 15, 2008 at 5:55 AM
