When we first got the car, it was sitting for a month. Drove it home. It was running real rough. I had to put the car in 1st to get it to even go. Got it home, let it sit over night, when I went to start it, it would turn over, backfire, then stall. Replaced the temperature coolant sensor, coil packs, plugs, and wires. Sense there is no cam shaft sensor, i'm thinking it may have jumped gears or the crank shaft sensor is bad. Any ideas would help. Thanks
SPONSORED LINKS
Tuesday, December 11th, 2007 AT 3:41 PM
