1988 Chevy Cavalier i think my egr valve is bad
1988 CHEVROLET CAVALIER
78,005 MILES • 4 CYL • 2WD • AUTOMATIC
BRANDONISAAC
I just got this car and it had problems with stalling and the voltage and battery light and check engine light would go on, and i found out that it was the alternator. After getting 2 of them replaced it started to drive like a champ. Now it stalls out here and there but no check lights go on. I read my repair manual and it led me to believe it was the egr valve. It said to test it by pushing on the diaphram, and to see if it is hard. I did that but im not sure if its bad or not. Do you think that the egr valve could be the problem? And if so, how can i check to make sure?
Feb 26, 2009 at 2:10 AM
RHALL77
  • 3,361 POSTS
can you pump it up with a vacuum pump? also check and see if there is any other vacuum lines that may be disconnected
Feb 26, 2009 at 3:41 AM
