1987 Chevy Cavalier Loss of power/compression and gas milea
183,000 MILES • 6 CYL • FWD • AUTOMATIC
KENNYD357
I have a 1987 Chevy Cavalier Z24 with 183823 miles on it. I bought the car brand new. At approx. 174600 miles, the car experienced a loss of power/compression. My gas mileage went from 26 mpg to 13 mpg. Trying to engage the passing gear is ineffective. I replaced the spark plugs, wires, 02 sensor, MAP sensor and accompanying hoses, added HEAT to the fuel system twice and replaced the fuel filter, with no success. At 181500 miles, I replaced the 3 ignition coil packs and that corrected the problem, for awhile. At approx. 183400, the problem returned. The car does not show any trouble codes and the check engine light is not on. I have not replaced the timing chain/belt. Does the computer have to be reset when the coils are replaced? Thank you for your assistance.
Jul 6, 2008 at 11:16 AM
MASTERTECHTIM
  • 4,750 POSTS
no it does not but if it acts like it did before then chances are you need to replace the ignition module. thats what the coils are bolted to. on this particular engine for some reason when a coil fails, the module is usually right behind. in fact when i replace a coil on this engine i replace the module too, every time because i have been burnt more than once.
Jul 7, 2008 at 10:48 AM
