1986 Chevy Cavalier car will not start
TSCHAFER
Engine Performance problem
1986 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
driving down the road car quit started on its own ran about 3sec quit again now will not start replaced control mod no gas or fire at plug coil ok
Sep 12, 2009 at 6:30 AM
JDL
  • 16,098 POSTS
Welcome to the forum. Without the rpm signal there won't be an injector pulse. The ignition module needs a trigger signal from the pickup coil. Did you check the coil primary terminals? Pink goes hot when you turn on the key, white wire should have a pulse with engine cranking.
My info shows an oil pressure switch in the fuel pump circuit, once you crank it enough to bring up the oil pressure and the switch closes, the pump will run and you should have pressure.
Sep 12, 2009 at 7:06 AM
