1985 Chevy Cavalier Starting
DENISECASSEL
Engine Mechanical problem
1985 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
I have a 1985 Chevy Cavalier 2.0L throttle body injected. We were driving down the highway and it died and would not start. We thought it was the ignition coil and replaced it, but it still won't start. Any idea to what is wrong so we can fix?
Aug 28, 2010 at 10:41 AM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem,If you can hear the fuel pump come On- check the fuel pressure with a fuel pressure tester designed for your fuel system to rule out the fuel filter/fuel pick-up strainer/fuel pump/pressure regulator and also listen to the injector/s are they pulsing or hook up a noid light and see if it flashing, If you don't hear the fuel pump, check the fuel pump fuse and fuel pump relay-Depends on what type ignition system is yours,No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, camshaft and crankshaft position sensors and computer Note: If it doesn't apply to your vehicle disregard it meaning if it doesn't come with one ignore it and continue testing
Aug 28, 2010 at 11:37 AM
