1985 Chevy Cavalier Setting timing
KING1974
Engine Mechanical problem
1985 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
How do you set timing on a 2.2 1985 Chevy Cavalier engine after the distributor was pulled and not marked?
Sep 1, 2008 at 1:37 AM
MMPRINCE4000
  • 8,548 POSTS
Remove spark plugs, rotate engine with ratchet on balancer bolt (clockwise).
Place finger on #1 spark plug hole, when you feel air coming out, rotate until balancer mark is aligned with timing mark (O degrees).
Install dist. so that rotor points to #1 cylinder (on cap).
Set timing with light after car is running.
Sep 2, 2008 at 10:24 PM
