1984 Chevy Cavalier wont start
120,000 MILES • 4 CYL • FWD • AUTOMATIC
VALINTINE92
my 84 cavalier died while i was driving it checked all fuses fuel pump runs not getting fire changed coil still no fire
Feb 12, 2009 at 2:16 AM
JDL
  • 16,098 POSTS
Did you check the coil primary circuits, the smaller wires? Pink is B+ should be hot when you turn on the key.
With the engine cranking, the brown wire should have a pulse. If your missing the pulse, you might suspect either the ignition module or pickup coil. I'm not sure of the litre size of the engine? The info I looked at was a 2.0.
Feb 12, 2009 at 2:56 AM
