Steering problem
1984 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
I NEED HELP REMOVING THE STARTER IN MY SISTERS 84 CAVALIER AND YOU HELP
Friday, July 4th, 2008 AT 11:32 AM
MERLIN2021
MECHANIC
Remove the negative(-) battery cable, then remove the wires at the starter, remove the two bolts holding the starter, be careful the starter is HEAVY! Use caution removing the last bolt. Install is the reverse of the proceedure!
