1984 Chevy Cavalier Bogs down
FRANK BLANK
Engine Performance problem
1984 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 150 k miles
My 84 Cavalier Convertable 2.0 4cyl engine, starts up
fine , but when I press the gas pedal down it bogs , spark plugs are sooty, could this be the map sensor or throttle body injector problem Please help Thanks
Sep 22, 2008 at 1:40 PM
BLACKOP555
  • 10,386 POSTS
tbi not carburated?
i would be checking the tps also disconnect the map sensor wiring harness. not the vaccum line. just the harness.
check tps voltage closed throttle then 1/4 throttle half and wide.
Sep 22, 2008 at 3:07 PM
