1983 Chevy Cavalier car cutting off when turn on any access
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
CJORDAN9
This is a progressive problem, started when I would try to turn on the ac and car would cut off, now trying to use anything while car is on lights, windows radio the car will cut off. I have replaced, belts, battery, altenator, starter, where do I look from here
Aug 18, 2009 at 9:52 PM
JDL
  • 16,098 POSTS
Hello, are all battery connections clean and tight. You can't really tell by looking, you need to take them loose and clean them. I usually take the negative loose first.
Aug 19, 2009 at 9:25 AM
