Engine wont Start...
SANDSHARK23
  • 7 POSTS
I have a 1992 Chevy Caprice 305 V8 with 138,563miles. I recently started experiencing coolant loss, and it was determined that I had a leaking head gasket. I changed the head gasket myself, however the process took me a few days because I didn't really have the time to do it all at once. After I put the ne gasket onto the engine and sealed everything up, I tried to start it and all I got was a click from the starter.
I thought maybe the starter was bad, but then I tested it and that turned out not to be the case. I tried to manually turn the engine, only problem is that it wont do a full rotation. It turns all the way with the exception of about 2 inches.
I originally thought that maybe I had left something in the cylinder when I was replacing the head but I've already checked that. so now I'm at a loss as to what could be causing the problem. any help would be appreciated. :?
Oct 4, 2007 at 8:05 AM
BMRFIXIT
  • 19,053 POSTS
[quote:9c298d6c67="Sandshark23"]I have a 1992 Chevy Caprice 305 V8 with 138,563miles. I recently started experiencing coolant loss, and it was determined that I had a leaking head gasket. I changed the head gasket myself, however the process took me a few days because I didn't really have the time to do it all at once. After I put the ne gasket onto the engine and sealed everything up, I tried to start it and all I got was a click from the starter.
I originally thought that maybe I had left something in the cylinder when I was replacing the head but I've already checked that. so now I'm at a loss as to what could be causing the problem. any help would be appreciated. :?[/quote:9c298d6c67]
pull all spark plugs out
and try to turn ?
Oct 4, 2007 at 10:26 PM
SANDSHARK23
  • 7 POSTS
I pulled out the spark plugs and tried to turn the engine, with no changes to the original problem. Is there anything else you could recommend I try?
Oct 5, 2007 at 2:14 AM
BMRFIXIT
  • 19,053 POSTS
[quote:c3c1df8a9a="Sandshark23"]I pulled out the spark plugs and tried to turn the engine, with no changes to the original problem. Is there anything else you could recommend I try?[/quote:c3c1df8a9a]
VALVE COVER OFF LOOSEN VALVES TRY TO TURN
Oct 5, 2007 at 2:18 PM
