It haves about 124,000 miles on it
It has an intermitent stalling problem, sometimes it will stall after starting and or at take off, but usually works fine after we get moving, although it has happened when we come to a light.
I've replaced the Throttle sensor, the Idle Air Control Valve, the fuel filter and put new plugs, rotor and cap on it.
I was going to check the timing, but the book says to disable the electronic spark timing system first, but I'm not sure how to do that.
Monday, November 26th, 2007 AT 8:55 PM
