1992 Chevy Caprice car idle low and cut off
1992 CHEVROLET CAPRICE
KINFOLK4LIFE74
Engine Performance problem
1992 Chevy Caprice V8 All Wheel Drive Automatic
when i pull up at a light or stop sign my car idle down and cuts off will it be the oxygen sensor or fuel pump?
Mar 2, 2010 at 4:25 AM
  • 110,244 POSTS
I question if either the pump or O2 sensor is causing it. Has the check engine light come on? Have you checked for vacuum leaks?
Mar 7, 2010 at 6:09 AM
KINFOLK4LIFE74
yes at first the check engine light was on but i had a test done on it and and it went off from time to time it will come on if im sitting in drive for a minute i have not had it checked for vacum leaks where can i locate the o2 sensor
Mar 8, 2010 at 3:37 AM
