I own a 94 Caprice Classic (9C1) and am experiencing the following problem. Vehicle is running hot, temperature gauge pegs out close to the red.
Cooling fans (primary/secondary) both work. Fan Relays also are working, Temperature sending unit also works. However, fans do not turn on unless I turn the AC on. Radiator & coolant along with all hoses are perfect.
I would like to know what other test I could preform to evaluate this condition. Also, any thought on by passing the PCM and installing a manual toggle switch inside the vehicle to controll the fans.
Thanks!
Thanks!
Jan 15, 2006 at 11:45 AM
