Alternator
MATHIS1796
1986 Camaro Z28. I have replaced my alternator 3 times. The car in on it's third Battery. I think the battery are being drained because I either don't have the alternator hooked up correctly or there's a problem with the alternator holding a charge. From what I can tell, the amps from the battery are pulling about 25% while running and the alternator will not pull the lights while running at night, it drains it immediately. Someone told me to disconnect the positive post of the battery while running the engine and if it goes dead, then the Alternator is bad. It does go dead but everytime I return the alternator they tell me it is passing the test. I'm at a loss for what to check next. Any thoughts?
Oct 8, 2007 at 7:50 AM
MERLIN2021
  • 17,250 POSTS
First off don't listen to the friend! Next check BOTH bateery cable especially the negative where it attaches to the engine...if you have a voltmeter, get back to me and I will tell you how to test for a parsitic drian! I believe if you clen your cables and the gounding points you will be OK!
Oct 8, 2007 at 11:01 AM
