2000 Chevy Blazer chronic fuel pump failure
GERALD HARDCASTLE
Electrical problem
2000 Chevy Blazer V6 Four Wheel Drive Automatic 150000 miles
replaced fuel pump and filter. New connector and harness. 1 month later +/- engine is starving for fuel at about 2,500 rpm....replaced again same thing about 5 wks......replaced and about 6 wks later time to do it again.....can anyone give a suggestion??
Dec 11, 2008 at 11:04 PM
MIKE H R
  • 3,094 POSTS
I am not much on the electric fuel pump I try to work with older cars, but off hand I would have the voltage checked going to the pump. Also check the ground. Too little voltage will burn out the pump.
Dec 17, 2008 at 5:58 AM
DOCFIXIT
  • 18,828 POSTS
Check ground and are you installing GM OEM pumps? If not that is likely the early demise
Dec 17, 2008 at 6:13 AM
