1996 Chevy Caprice no fuel pressure
CAPRICE9C1AZ
Engine Mechanical problem
1996 Chevy Caprice V8 Two Wheel Drive Automatic
No fuel pressure.changed filter and fuel pressure regulator.car will not start.how do I check/change fuel pressure switch?or should I just replace pump?
Oct 30, 2010 at 11:17 AM
WRENCHTECH
  • 20,760 POSTS
You should stop simply throwing parts at it and do the necessary testing. You need to test for power arriving at the pump during the first 2 seconds of "key on". This will require 2 people to test.
Oct 30, 2010 at 12:23 PM
