1996 Chevy Caprice Heater air
1996 CHEVROLET CAPRICE
KARNUT0
Heater problem
1996 Chevy Caprice 6 cyl Four Wheel Drive Automatic
Heater is blowing luke warm air with the temp control set at maximum. Car temp. reads a constant 180 degrees. Is there a heat control valve on this engine and is it easy to replace?
Nov 22, 2008 at 5:02 AM
  • 110,244 POSTS
Hi:
Feel the heater core hoses and make sure they are both hot. Let me know what you find. Also, the engine temp usually should run between 190 and 200. You may have a t-stat sticking open.
Nov 29, 2008 at 2:51 PM
