1996 Chevy Caprice FUEL PUMP
185,000 MILES • V8 • 2WD • AUTOMATIC
ZAYE
  • 5 POSTS
MY MECHANIC WAS SUSPOSED TO RUN A HOTWIRE TO MY FUEL PUMP BECAUSE I KEEPS BLOWING A FUSE TO MY FUEL PUMP. SOME DAYS IT WILL RUN FINE AND SOME DAYS IT WILL BLOW. SO I WANTED TO KNOW SHOULD THAT HOTWIRE BE RAN AND IF SO HOW TO DO IT. THANKS
Sep 13, 2008 at 7:35 AM
  • 75,988 POSTS
If you wish not finding where the short circuit is-use a toggle switch and go straight to the gray wire on the fuel pump connector from the battery.
Sep 13, 2008 at 7:50 AM
ZAYE
  • 5 POSTS
when attaching the toggle switch to the grey wire will this keep the fuel pump fuse from blowing out.
Sep 13, 2008 at 10:18 AM
  • 75,988 POSTS
Cut the gray wire coming from the front side-and hook up your power to the gray wire to the connector going into the fuel pump.
Sep 13, 2008 at 9:33 PM
ZAYE
  • 5 POSTS
so when i connect the toggle switch to the grey wire is the grey wire the hotwire? and if so do i need to ground the other wire. also if possible can you give me step by step instructions.
Sep 14, 2008 at 3:19 AM
  • 75,988 POSTS
Get a wire as thick as the gray wire connect it the battery positive post run it thru the firewall position it where you can reach it cut the wire connect it to the toggle switch then take it to the gray wire-
Sep 14, 2008 at 4:58 AM
