1995 Chevy Caprice LT1 MOTOR WITH 4L60E TRANSMISSION OUT OF
TERRYHEARN
Transmission problem
1995 Chevy Caprice V8 Two Wheel Drive Automatic
my transmission was working fine i pulled into a gad station to get fuel once i left the station my transmission would not change out of first gear.I took my transmission out of my 1995 chevorlet tahoe that also has a 4l60e i also put the fly wheel from the tahoe in the caprice also all fitted fine and is bolted into car but niether of the starters will fit the tahoe starter bolt pattern is wrong and the chevy caprice starter wont fit inside the bell of tranny to work what starter can i buy that will work ????? and i also have a 1996 chevy camero will that tranny work with stock starter ??????????????
Apr 8, 2010 at 4:30 PM
HMAC300
  • 48,601 POSTS
the camaro trans will work if you want to use that. You might also try changing the starter noses from the truck to the car or vice versa. you just neeed to take off 2 bolts at the back and starter solenoid.
Apr 26, 2010 at 11:13 AM
