1995 Chevy Caprice HOOD RELEASE
10,000 MILES • V8 • 2WD • AUTOMATIC
COCINERO
I pull on the hood release and nothing happens. I tried using a smal vice grips to grab the wire and pulled but still nothing. how else can I pop the hood?
May 24, 2010 at 12:53 AM
MMPRINCE4000
  • 8,548 POSTS
If cable has detached from latch it's going to be a problem.
Raise car, put on stands, remove front left wheel and plastic water shields.
See if you can get a hand up to latch and pull.
Inspect assembly and replace cable or latch or both.
May 24, 2010 at 1:24 AM
