1995 Chevy Caprice CAR IS MOVING SLOW
184,000 MILES • V8 • 2WD • AUTOMATIC
SUPERDARREN777
When I take off the car is sluggish and I dont know what to do ?
Mar 30, 2010 at 8:06 AM
  • 75,988 POSTS
Hi superdarren777,Welcome to 2carpros and TY for the donation.
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 30, 2010 at 8:36 AM
