1994 Chevy Caprice Temp Gauge
1994 CHEVROLET CAPRICE
136,000 MILES • V8 • 2WD • AUTOMATIC
MARK24
  • 10 POSTS
Could you tell me why my temp gauge is not working I put a new sensor in and it is still not working allways stay's on the cold side and when I turn the key to start it well not move THANKS
Dec 14, 2008 at 4:21 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
You say you have already replaced the temperature sending unit?
Check your fuses to ensure none are blown. Also check the wiring to the temp. sending unit to ensure they are not loose or broken. If not these, it could be something in the cluster itself.
Post your results and I will follow up.
Dec 14, 2008 at 4:29 PM
