1994 Chevy Caprice Temp. gage wont heat up
DEFINIT
  • 9 POSTS
Heater problem
1994 Chevy Caprice V8 Two Wheel Drive Automatic
I drive the car and the temp. gage wont heat up unless idoled then once you get going it cools right down, what is this about??? Thanks.
Dec 2, 2008 at 10:36 AM
MASTERTECHTIM
  • 4,750 POSTS
sounds like a open thermostat. try replacing it and see what happens
Dec 2, 2008 at 10:47 AM
DEFINIT
  • 9 POSTS
I thought it might have been that, but I always thought it would over heat with the thermostat, but I take it that would be a brocken closed thermo.?
thanks you
Dec 4, 2008 at 11:41 AM
DEFINIT
  • 9 POSTS
I changed the thermostat and flushed it adding new coolant. I let the car idol with the coolant cap off for about 45mn. it was finally hot and the temp gage was in the hot zone. I took it for a ride and the gage started going cold and the air started blowing cold.??????????????
Dec 17, 2008 at 2:15 AM
