1994 Chevy Caprice serpentine belt
13,000 MILES • V8 • 2WD • AUTOMATIC
DAVEQ
Hi im trying to put the belt back on but its just not going back on and I already put the water pump back on is there any other way i can loosen something for me to put the belt back on
Aug 21, 2009 at 6:59 AM
DOCFIXIT
  • 18,828 POSTS
Hi Guessing you didn't release belt tensioner to remove belt. Have diagram of two types used it maybe a little small but can print and enlarge.Tensioners are spring loaded so you crank it put belt on release and belt is adjusted. Hope this helps Thanks for donate
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_93.jpg
Aug 21, 2009 at 7:10 AM
