1994 Chevy Caprice pinion gear shaft
1994 CHEVROLET CAPRICE
SPYLER
Drive Train Axles Bearings problem
1994 Chevy Caprice V8 Two Wheel Drive Automatic
I removed the lock bolt, however i can not get the pinion shaft out. I tapped it out about a half an inch with an air chisel with a blunt end on it but it will not come out easily at all. What do i need to do.
Thanks
Mar 11, 2010 at 9:07 AM
HMAC300
  • 48,601 POSTS
these sometimes have to be cut out. but try moving the carrier to a different position and try moving it from there. Also the bolt shoul d be about an inch or so long and did all of it come out, as they break a lot of times and cause what you are experiencing...someitmes you have to break the carried to get the pin out.
Mar 19, 2010 at 11:29 AM
