1994 Chevy Caprice engine starts but won't stay running
95,000 MILES • V8 • 2WD • AUTOMATIC
RABATVILLE101
i change the coil, ignition module and distributor it won't stay cranked
Apr 15, 2010 at 3:53 AM
  • 75,988 POSTS
Sounds like the ignition system is doing its job-Check the fuel pressure if its within specs if okay clean out the idle air control valve and see what happens.
Apr 15, 2010 at 4:00 AM
