i change the coil, ignition module and distributor it won't stay cranked
Apr 15, 2010 at 3:53 AM
✓Experienced Mechanic
1994 Chevy Caprice engine starts but won't stay running
Sounds like the ignition system is doing its job-Check the fuel pressure if its within specs if okay clean out the idle air control valve and see what happens.
