1994 Chevy Caprice coolant temp sensor/check engine light
173,000 MILES • V8 • 2WD • AUTOMATIC
SUWOOP-KING
Ok I have a 1994 chevy caprice 173,000 miles on it my car runs like a champ the other day I noticed my check engine like popped on and I was cocern because I take good care of my car so I immediatly took it to pep boys and had it scanned a code 15 was the code it read which was a coolant temp sensor ........and every since this my car doesn't start right away.....so the next day I popped my hood and noticed the plug to the coolant temp sensor was daggling and I plugged it back up started the car check engine light went off and car fired right up so I knew that was really the problem.. now the thing is I still need a new sensor because the clip is broke on the sensor and won't stay plugged in so I bought a new sensor put it in and my check engine light came back on and my car won't start on the dime like it does....what could this problem be do I need to drive my car for awhile until in registers in the computer because I even installed the old sensor and everything works good....or do I have to get the code cleared or what help me out please thanks......
Jun 24, 2009 at 5:17 AM
CAPRICE9C1
Sometimes it will take the computer a while to adjust to the new sensor. If you want to clear the code from the computer save yourself a trip to the auto parts store and just unhook the battery for about 10 minutes. This will reset the computer and after running for a little while it should readjust and be fine provided the new coolant temp sensor is working correctly.
Jul 12, 2009 at 6:17 AM
