1994 Chevy Caprice CONTROL ARM BOLT
1994 CHEVROLET CAPRICE
87,900 MILES • V8 • 2WD • AUTOMATIC
NIKKIARMSTRONG
I AM MISSING A CONTROL ARM BOLT FROM THE DRIVERS SIDE OF THE CAR I TOOK MY CAR TO GET A FEA AND THEY SAID I WAS MISSING A BOLT FROM THE CONTROL ARM AND THAT THEY WERE UN ABLE TO DO THE SERVICE I NEED TO KNOW WERE I CAN JUST GET THE BOLT FROM
Apr 19, 2010 at 8:58 AM
HMAC300
  • 48,601 POSTS
if you know what bolt iis missing and wha tsize it is then you might be able to get eh bolt at the hardware store. In your case it would need a harness of at least 10.9 which on factory bolts are marked on the head. If not you'll have to go to the junk yard. Ifi's the sway bar bolt then just get a kit as new bolts come with it. And just change both sides..
Apr 26, 2010 at 11:04 AM
