1994 Chevy Caprice condensation
1994 CHEVROLET CAPRICE
98,000 MILES • V8 • 2WD • AUTOMATIC
STEELERFAN11
i have condensation running inside the car on the inside of the firewall its not antifreeze definatly water not sure where drain is supposed to be and there is no condensation on the ground when a/c is on.
Jul 26, 2010 at 12:37 PM
HMAC300
  • 48,601 POSTS
you'll have to crawl under the car on teh passenger side. You'll see a rubber hose near the front of the transmission, it will be about 1/2" round. Take a piece of wire or coat hanger and run it up and down insde it. it will drain the water out that has accumalated from the a/c running. Yes you'll getwet.
Jul 27, 2010 at 10:35 AM
