1994 Chevy Caprice !994 chevy Caprice Water N Back
1994 CHEVROLET CAPRICE
MIAMIINSKEGEE
1994 Chevy Caprice V8 Two Wheel Drive 102000 miles
When I drive my car with the air condition on My Floor on the rear passenger side gets a puddle of water right in the center. and even when I don't run the air it gets damp. I checked my antifreeze dosent get low no matter how much watter stands in the floor
Jul 22, 2009 at 2:49 AM
JMALECKI
  • 118 POSTS
Hello
there is a drain on the passenger side of the firewall under the vehicle, more than likely this is plugged up.
From under the car you should see a rubber elbow take a stiff piece of wire pinch the end of the tube and use the wire to clear the inside of the tube. hope this helps.
John
Jul 26, 2009 at 5:35 AM
