1994 Chevy Caprice 94 Caprice will not crank.
167,000 MILES • V8 • 2WD • AUTOMATIC
MSP9C1
I've got a '94 Caprice, an old police car with the LT1 engine.
It suddenly quit starting. It was running fine one day and then the next I could not get it to crank.
When I turn the key I can get power to the car, windows, radio and dash lights work ; however when I turn the key to the 'start' position..nothing happens. I get no noises, no attempt to crank at all.
What is the most likely problem and is there an simple way to check it out?
Thanks in advance.
Oct 11, 2008 at 6:56 AM
DOCFIXIT
  • 18,828 POSTS
Hi msp9c1
Get a test light jack up put light on solinoid term ,small wire, have someone turn key if it lights starter bad if not ign switch.
Let me know
Thanks for donation
P.S. maybe neutral safety switch
Oct 11, 2008 at 7:08 AM
MSP9C1
Thanks for the tip, looks like I need a starter.
Oct 16, 2008 at 6:46 AM
