1993 Chevy Caprice WHITE SMOKE
YOUME
Heater problem
1993 Chevy Caprice Engine Size unknown Wheel Drive Type unknown Automatic 59000 miles
okay, so the problem is white smoke. COOLANT is FULL..water and antifreeze . I added those three days before i started seeing smoke. I don't know whats wrong. The heat temperature for the engine is not even close to the red line, oil is brand new, battery is new...i just don't know why i drive only for 15 minutes and i'm already seeing smoke...and if i drive it too long without getting it checked, will it damage anything?
Feb 5, 2008 at 2:47 PM
  • 75,988 POSTS
While smoke is an indication of coolant being burn in the combustion chamber.
Could mean a blown headgasket crack head or block. To find out get it block and pressure tested
Feb 5, 2008 at 3:05 PM
