1993 Chevy Caprice Replacing 305 with a 350
305 TO 350 GUY
Engine Performance problem
1993 Chevy Caprice V8 Two Wheel Drive Automatic 82,xxx miles
Good Day!
I am replacing a seized 302 in my 1993 Caprice with an older 350. I would like to keep the car's fuel inection system, and simply beef up the injectors and pump, but I don't know if I will need to have the Electronic side "adjusted/replaced."
Also, how can find out if the transmission in the Caprice will work properly with a 350ci engine?
Thank you for your time!
Jun 23, 2010 at 8:03 AM
HMAC300
  • 48,601 POSTS
going from a 305 to a 350 is a bolt in swap. You may beable to use the same computer setup but would be better for the one for a 350. The fuel injection is a different size for teh 350 but you could get away with using it.
Jul 2, 2010 at 7:17 AM
