1993 Chevy Caprice Missing badly at idle, but not as bad at
TOMSUBLETT
Engine Performance problem
1993 Chevy Caprice V8 Two Wheel Drive Automatic
Trying to figure out if this is a vacuum leak or ignition problem.
Feb 28, 2009 at 5:23 AM
DOCFIXIT
  • 18,828 POSTS
Check EGR oull off see if pentil is closing. If good spray carb cleaner around intake and throttle body. If a vac leak engine will idle up when you spray at the leak.
Feb 28, 2009 at 5:52 AM
